Ocelot on USB Serial Hub works with CMAX but not HS? Why not? It always get stuck at "initializing IO". I set it to COM4, which is the first port on my Comtrol USB Serial Hub.
Running Win2k Pro. Any thoughts? Perhaps HS only allows the IO interface to work with standard COM ports - as there appears to be no "setup" available for Applied Digital under Custom Interface?
