Leopard script setup
This topic is closed.
    I have been messing with what Carl has done on Linux with the Leopard.
    He has written in C a program that can put screen updates on the fly.
    Main page
    http://www.denninger.net/homedaemon.htm
    Details on Leopard
    http://www.denninger.net/HomeDaemon/leopard.htm
    Here is the tar'd pacakage
    http://www.denninger.net/HomeDaemon.tar.gz
    I dont no any C at all.
    Do you think this is doable? Can it tie it into HS?
    Brett,
    While it is possible to do what Karl is doing with a script, you can't do it while using the ocelot plug-in. As the name implies, Ocelot Plug-in, means that it doesn't know anything about the touchscreen on the Leopard. You would have to de-install the ocelot plug-in and write a script that talks directly to the leopard using Homeseer's serial port function calls.
    Ken
      That helps, I was trying call this will the plugin.
      Makes sense. I will be trying it again.
