Alright, My Ocelot is on its way so I want to get prepared.
This topic is closed.
    Is the Ocelot plugin delivered with HS 1.6. I would look but I'm on vacation and do not have access to my PC. Is it as simple as plugging in the Ocelot and firing up the plugin?
    -Rupp
    ...One Nation Under GOD, Indivisible, With Liberty And Justice For All.
    Sure nuff
      Rupp - not sure cause it's been a while, but you may need to load CMAX and update the Ocelot's firmware first.
      Joe
        I bought the Ocelot from a friend on the board. First off, how will I know what firmware is loaded? Where do I get the latest firmware. Do I want the latest version or is there a version I should look for. Thanks for the reply.
        -Rupp
          Rupp, you can get the latest software and flash here.
          ocelot
          Tom
          Digi-house
            One link is to C-Max V1.70j (includes Flash V3.01) and just below that is a link ... "Click here to download Flash512.bin" Which do I need?
            -Rupp
              Rupp, I just recently updated the flash for mine. I just used the version that came with the C-max download. I hadn't had trouble with the older flash installed. I moved everything to a new machine and the x10 signals stopped working. I updated hopeing to fix the problem. Come to find out it was just noise on the wall plug. The new flash works fine. You have to load the flash with the c-max software before homeseer has control of the ocelot. If there is no flash loaded when the cmax software tries to connect to the ocelot it will pronpt you and ask if you want it to install the flash.
              Tom
              Digi-house
                Since you are getting it from someone, if htat person was using it then it may already have a recent enough firmware upgade. You still will want to download CMAX and install it. Run it just to see what version you have and compare it to what's available.
                  I should have it when I get home from the beach.
                  -Rupp
                    Yep...Sure nuff
