I'm running a CMAX program that makes heavy use of variables. I do not use variables as Triggers to homeseer, but I notice that the bulk of my hstrace.log is filled with event checks for the CMAX program activity because this program is using the variables for its internal operations as well as providing status visibility.
When I setup the WebAgent plugin I allowed the user to define the level of trigger's to be generated by WebAgent. This was to eliminate many callbacks which most users did not need, but could be enabled for special situations.
It would be nice if the ocelot plugin could allow a setup that not only defined variables, but also enabled/disabled trigger events from the ocelot.
