Setting module parameters via CMAX: impossible
This topic is closed.
    I have a problem with my Ocelot and Secu-16 modules.
    When i run up CMAX to change a module parameter, if I click on the module parameter value, it simply doesn't give me any way to change it.
    I need to set some of the parameters to different values and this is driving me up the wall!
    The Ocelot is talking fine to the Secu16; HS and CMAX both process signals in and can set relays out.
    Anyone else found this problem and more important, a solution?
    Simon,
    If you're on the screen I think you are, then there is a password box at the bottom of the screen. The password is the value of parameter 6 for module 1. Enter that and you should be able to change module parameters.
    jim
      You are absolutely right - thank you!
      where did you find out the solution? I thought I had read all the documentation on the ADI website and there was no mention of the password setting.
      Where did I miss it?
        Simon,
        Glad that was it. I picked it up off the AppDig mailing list at some point. The only place I've seen it documented is in an application note on their site - #9 Using C-Max To Change Module Parameters.
        jim
