Redoing the variables ?
This topic is closed.
    When installing the Ocelot for the 1st time there was a msg saying something like ... "Create variables ? Yes or No (you can create them later if you wish)". Not knowing what it was about, I said No, but it subsequently appears that these are required for HS to receive the IR signals received by the Ocelot. Unfortunately I cannot find any reference on how to "create these variables later", and the original msg has not re-appeared since, even though I've un-installed and re-installed the Ocelot.
    I've looked through HS help and spent a couple of hours searching the Message Board, all without success, so can anyone tell me how I can get the variables created without doing a complete clean install of everything ?
    Fingers crossed, Robin.
    In the options section under interfaces, select the Ocelot plug-in for RF,IO, Security/Other then select setup. You will be shown a dialog with a button to create devices. Do that and you'll be set.
    -John
      Just the job, thanks for the info.
