Hey Guys,
I need some advise on setting up my Ocelot. Since my CM11A is using my only serial port, I bought a USB to Com Port adaptor for the Ocelot. It appears to be working great with the
C-Max software but I'm getting an error message in the HS log when I start up.
~!~startup~!~Initializing Infrared Interface
~!~Info~!~Ocelot Plug-in, Version 1.0.22
Error~!~Ocelot Plug-in, Ocelot init error: Could not set comm state, there may be one or more invalid communications parameters.
~!~Error~!~Initializing custom IR device: Ocelot init error: Could not set comm state, there may be one or more invalid communications parameters.
I set up the Ocelot in the interface tab under options. I selected "Applied Digital Ocelot" as my inferred device and set it to com 4.
I was able to then start the ir learning. When I tested the learned ir command, nothing happens. I think it's because HS is having some communication problem with the com port. (I'm Lost)
I went back and re-tested the Ocelot using C-Max and it worked great. Can anyone help me figure out why HS is not working with it?
Tony
Tony
