How to code for multi-zone IR with CMax 2.00c?
This topic is closed.
    I would like to use multiple IR zones on Secu16IR to send IR to different rooms in the house. The module runs as module 3.
    When I try to code Transmit IR in Cmax 2.00c, I have an option to choose module 3. When it is selected, then ALL other options disappear. By default from previous selections the zone remains 0. I cannot change it to any other fixed zone (or zone linked to a variable value).
    Is it only my problem, or someone else encountered this? Where do I make mistake?
    Do you have Module #3 defined as a secu16ir in the project's system map?
    jim
      Yes - this was the issue. I can at least issue IR on remote zones from CMax. I still can not send IR signals directly from I/R config dialog in the HomeSeer. I think it is configured well because I can see the zones.
      Thanks again - you got it working!
