My Ocelot, SECU16, SECU16IR, PSC05 and a handful of IR emitters arrived yesterday. I've read a lot of the posts here about setting everything up and was wondering if anyone had advice to offer.
I know that I've got a lot of stuff to get setup, and should probably work with a module at a time, so what do you all think the best approach is?
Here's what my plans are:
Continue to use the CM11A as my HomeSeer x10 interface, but passing some things off to the Ocelot to do on its own with the PSC05.
Use the SECU16's inputs with the cr-magnetics current switches (on order) to give me discrete/conditional control via on/off sensing of my Home Theater Equipment in conjunction with the SECU16IR.
Use one of the SECU16's outputs to close the power switch on my HomeSeer computer in conjunction with a watchdog script.
Should I address the modules one at a time, get them working with CMAX and then start using them with HomeSeer. Should I address both modules before I go into HomeSeer?
Which Ocelot plugin would be best for this setup?
It's going to be two-weeks before I can REALLY dedicate a lot of time to the setup, my wife's going on a week-long business trip in mid-November, so I'll have a lot of time to dedicate to getting everything working without neglecting my lovely bride.. and to get everything working so my WAF won't fall through the floor!
| My HomeSeer | HomeSeer Webring | My Profile
[This message was edited by jrfuda on Mon, 27 October 2003 at 10:45 PM.]
[This message was edited by jrfuda on Mon, 27 October 2003 at 10:52 PM.]
[This message was edited by jrfuda on Sat, 15 November 2003 at 12:14 AM.]
