wired motion sensors
This topic is closed.
    I am replacing all my x10 motion sensors for wired sensors to a secu16.( they gave a lot of x10 interference)
    The sensors give a short on by motion and then direct an off. So the motion detected status is just for a very short while. I want to turn on the light with it and turn it off after 5 min. of no motion. What is the best solution to do this in homeseer? I have the doomotion plugin.
    Peter
    http://www.pvanderhorst.nl
    Peter
    http://ohh.pcgsm.nl
    I'm not positive, but I do not think the SECU16 has latches on its inputs. They are strickly levels. This means that short pulses will likely be missed some/most of the time. If memory serves me, the cpuxa cycle in the ocelot is nominal 1 second. If the pulses are not at least then long then you will likely have problems.
      Dan from AppDig used to be on the HS board a lot but haven't noticed him lately.
      I would think they would be the best source of how to handle this.
      It would be great if you would copy his responses back here. I am considering a similar situation.
      SteveP
      I Pledge Allegiance to the flag of the United States of America and to the Republic for which it stands, one Nation under God, indivisible, with liberty and justice for all.
      The REAL Pledge of Allegiance
        AFAIK . . . when set for supervised inputs, the Appdig units (Secu16, Secu16I) are of the 'latching' type, they will report a status change no matter how short the input is tripped . . .
        . . . found a thread at the ADI message board that pretty much supports my assumption . . . check the 4th & 5th messages in the list . . .
        Pete C
        [This message was edited by pete17c on Mon, 19 January 2004 at 07:29 PM.]
          I have both X10 and hard wired Motion sensors. I found the hard wired ones to be much better until i got the W80032 device and then I found the X10 sensors wher much more flexable fast and they do not clog up the Power line...
          Andrew
          Fast, Secure, Reliable, Profitable, Satisfaction.
            The input of the sensors works.
            I will explain how I did it with homeseer:
            When input goes on a variable is set and a timer for 300 sec.
            New motion resets the timer, so variable is 1 and stays 1 by motion and 0 after 300 sec of no motion.This is done by the ocelot.
            In homeseer I made 2 events to switch on/off a virtual device (z1).
            On when var=1 and z1 = off.
            Off when var=0 and z1 = on
            I made z1 a doomotion sensor.
            A new event is triggered by conditions of z1 and if it's dark or late night to set the light to:
            20% > no motion and dark
            40% motion and after 11 pm
            60% motion dark and before 11 pm
            This all works, but is'nt there an more easy way to get this?
            Peter
            Peter
            http://ohh.pcgsm.nl
              Peter,
              would you be willing to share the script you are using?
                attached the snipped.
                Peter
                Peter
                http://ohh.pcgsm.nl
                  Thanks Peter!
                  I'll take a look at it and give it a shot.
                  Marty
