I have a motion sensor conected to the secu 16
When motion is detected the input goes off for a short while(99).
It triggers a timer(104) and a variable(105) and switches the kitchen light on.
When new movement is detected within 300 sec, the timer is reset to 1(107)
When more than 300 sec are gone without movement, the light turns off(111)
But sometimes the light will go on without any reason after about 4 or 5 sec.
I don't know what I am doing wrong.
I made an extra safety with (115), that will switch the light off a second time after 30 seconds.
Sometimes the light goes just off,
sometimes the light goes off , on and off again.
sometimes the light goes off on off on off.
And when you activate the sensor the light stays off, but the timer is counting.
Can anybody help me?
thanks,
Peter
0099 - IF Module #6 -SECU16 _4 Secu16 Unit 6 Input 4 keuken Turns OFF // movement kitchen
0100 - AND Ocelot keuken timer V10 is = 0 // first time
0101 - AND Ocelot dag/nacht-0-1-2-3 V05 is > 0 //
0102 - THEN Transmit X10, K - 5 //
0103 - THEN Transmit X10, K - ON (19) //
0104 - THEN Timer-#10-keuken = 1 //
0105 - THEN Ocelot keuken timer V10 = 1 // light on
0106 - //
0107 - IF Module #6 -SECU16 _4 Secu16 Unit 6 Input 4 keuken Turns OFF // stay on with motion
0108 - AND Ocelot keuken timer V10 is NOT = 0 //
0109 - THEN Timer-#10-keuken = 1 //
0110 - //
0111 - IF Timer-#10-keuken is > 300 // after 5 min. off
0112 - THEN Transmit X10, K - 5 //
0113 - THEN Transmit X10, K - OFF (20) //
0114 - THEN Ocelot keuken timer V10 = 0 // can go on again
0115 - IF Timer-#10-keuken is > 330 // after 30 sec again off
0116 - THEN Transmit X10, K - 5 //
0117 - THEN Transmit X10, K - OFF (20) //
0118 - THEN Timer-#10-keuken = 0 //
0119 - THEN Ocelot keuken timer V10 = 0 //
0120 - //
0121 - IF Timer-#10-keuken is > 3 //
0122 - THEN Load Data to: Ocelot keuken timer V10 //
0123 - //
0124 - End Program // ********************************************************
thanks,
Peter
0106 - //
0110 - //
0120 - //
0123 - //
