HOw do I Remove the plugin from the top menu?
This topic is closed.
    Greetings,
    I removed the plugin under "View/Options/Interfaces" but it still shows up across the top menu bar.
    Help....I wish there was a better way to remove these plugins....
    All plugins should either remove the menus when you uninstall the plugin via the interfaces menu or offer a remove menu at the bottom of the drop down menu on the main interface. Does this plugin not offer this? Did you try shutting down HS and restarting after removing the plugin to see if the menus are removed?
      I removed the plugin under "View/Options"
      Shut down HS and restarted. Still there at the top.
