IR Questions
This topic is closed.
    IR Questions
    I'm trying to learn a Philips DSX5353R Satellite receiver. After looking over some posts I have tried fresh batteries, killed the ambient light, and even tried CMax. Is there some way to determine the carrier fecquency of the remote? This monster can't be learned on a learning remote either.
    Any suggestions?
    Don
    Don
    It uses the Philips RC6 protocol at 36KHz. I suspect that because of its somewhat unusual protocol it may be hard for some remotes to learn it. But I generated all commands for that device using GenIRDB. You should save your existing lir file using CMax. Then load this file into the Ocelot and test. If that works for you use IRMax to merge the two lir files.
    Here are the commands. The left hand column is the IR position that teh commands are in. I added the discrete power commands and they are untested but that is typically what Philips uses:
    IR# 1 Numeral 0
    IR# 2 Numeral 1
    IR# 3 Numeral 2
    IR# 4 Numeral 3
    IR# 5 Numeral 4
    IR# 6 Numeral 5
    IR# 7 Numeral 6
    IR# 8 Numeral 7
    IR# 9 Numeral 8
    IR# 10 Numeral 9
    IR# 11 Numeral Previous Program
    IR# 12 Numeral Power
    IR# 13 Numeral Power On
    IR# 14 Numeral Power Off
    IR# 15 Numeral Output TV/Sat
    IR# 16 Numeral Text
    IR# 17 Numeral ALT Audio
    IR# 18 Numeral Menu
    IR# 19 Numeral Exit
    IR# 20 Numeral Cursor/Ch Up
    IR# 21 Numeral Cursor/Ch Down
    IR# 22 Numeral Cursor Left
    IR# 23 Numeral Cursor Right
    IR# 24 Numeral OK
    IR# 25 Numeral Red
    IR# 26 Numeral Green
    IR# 27 Numeral Yellow
    IR# 28 Numeral Blue
    IR# 29 Numeral White
    IR# 30 Numeral Back
    IR# 31 Numeral Favorite
    IR# 32 Numeral Info
    IR# 33 Numeral Guide
    IR# 34 Numeral Themes
    IR# 35 Numeral Page Up
    IR# 36 Numeral Page Down
    IR# 37 Numeral Options
    IR# 38 Numeral Wink
