Itunes error
This topic is closed.
    Itunes error
    This morning I tried to play some music but stumbled with this error in HS log:
    7/15/2008 7:56:41 AM - iTune - Warning, unable to create playlist: Library not registered. (Exception from HRESULT: 0x8002801D (TYPE_E_LIBNOTREGISTERED))
    Anybody knows what this means???
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    This is an iTunes error. Try shutting down iTunes and HomeSeer and restart both.
      Did that, but still have error... I also restarted PC, no luck.
      Hector
      Win.2003 OS, HS3
        Did you move or change the location of your iTunes library? iTunes is very particular about how songs are added to its library. Try playing your songs manually with iTunes. If they do not play then you know the problem is with iTunes, not Homeseer.
        Steve Q
          Steve
          I can play the song on itunes but cannot in HS. I also reloaded itunes w/no luck. When I play thru itunes I can see title of song in HS being procesed.
          Hector
          Win.2003 OS, HS3
            Did you update to the new Version of ITUNES? (ver 7.7 i think)
            If so.. perhaps ITUNES changed something.. i know one of the new features in 7.7 is the ability to remote control ITUNES via IPHONE or ITOUCH.
            Just a thought.
            Andrew B.
              I upgraded to iTunes version 7.7 and I am also seeing this error message. However I did not see it until today. I think it may have something to do with my main computer (non Homeseer computer). When I turned it off, the error messages started.
              Any ideas?
              Steve Q
                OK, my memory started working again. I remembered that I had seen this problem before.
                To fix it type "iTunes /regserver" in the "RUN" prompt of the START MENU.
                Apparently the update does not automatically register with Windows XP Pro.
                Steve Q
                  I still need help. Ive reloaded itunes plug twice, Ive restarted HS,Ive restarted PC. Iam still getting the same error. i even placed help ticket and they still havent given me a solution... itunes works fine if, its the plug!!
                  Hector
                  Win.2003 OS, HS3
                    What version of iTunes are you running?
                      Since I had to reinstall, it should the lastest ver. the one with the VR commands.
                      Hector
                      Win.2003 OS, HS3
                        Did you see Steve's fix below?
                          Soory rupp, I did not see steves reply, I going to try it, thanks.
                          Hector
                          Win.2003 OS, HS3
                            When I enter itunes/regserver in the "Run" promtp, Its says "windows cannot find iTunes regserver"
                            Hector
                            Win.2003 OS, HS3
                              There must be a space between iTunes and the /
                              enter "iTunes /regserver" in the RUN prompt line on your Homeseer computer.
                              Steve Q
