Strange error - Totally killing HS.
This topic is closed.
    So I restarted HS and I get a constant loop in the Homeseer log.
    11/20/2010 4:36:30 PM ~!~iTunes~!~The number of tracks in the main library has changed from 0 to 4407
    11/20/2010 4:36:30 PM ~!~iTunes~!~A change to the main library has been detected, re-loading...
    11/20/2010 4:36:30 PM ~!~iTunes~!~Loading library in the background, this could take a few minutes...
    11/20/2010 4:36:30 PM ~!~iTunes~!~iTunes library file: C:\Documents and Settings\Administrator\My Documents\My Music\iTunes\iTunes Music Library.xml
    11/20/2010 4:36:30 PM ~!~HSTouch Server~!~Downloading image file http://192.168.1.210/image.jpg aborted, taking too much time.
    11/20/2010 4:36:31 PM ~!~iTunes~!~Error loading library: An error has occurred while opening external DTD 'http://www.apple.com/DTDs/PropertyList-1.0.dtd': Unable to connect to the remote server
    11/20/2010 4:36:31 PM ~!~iTunes~!~Finished loading Playlists
    11/20/2010 4:36:31 PM ~!~iTunes~!~Library loading completed.
    11/20/2010 4:36:34 PM ~!~iTunes~!~The number of tracks in the main library has changed from 0 to 4407
    11/20/2010 4:36:34 PM ~!~iTunes~!~A change to the main library has been detected, re-loading...
    11/20/2010 4:36:34 PM ~!~iTunes~!~Loading library in the background, this could take a few minutes...
    11/20/2010 4:36:34 PM ~!~iTunes~!~iTunes library file: C:\Documents and Settings\Administrator\My Documents\My Music\iTunes\iTunes Music Library.xml
    11/20/2010 4:36:35 PM ~!~iTunes~!~Error loading library: An error has occurred while opening external DTD 'http://www.apple.com/DTDs/PropertyList-1.0.dtd': Unable to connect to the remote server
    11/20/2010 4:36:35 PM ~!~iTunes~!~Finished loading Playlists
    11/20/2010 4:36:36 PM ~!~iTunes~!~Library loading completed.
    So it appears that apple.com is not allowing connections - I tried on several devices. My question is why you would you code up a sytem that takes out HS if you can't get to apple.com?
    Fo rnow I've had to remove the plugin, so HS will start... A bit of a bummer, I have a part tonight and no music via HS, isn't a good start.
    D.
    HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
    BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
    DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
    The HomeSeer plugin isn't attempting to connect to apple, your itunes app is. Are you running the latest version of the iTunes plugin? Do you have something in your iTunes app trying to pull information from the iTunes site?
      Rupp I doubt it itunes runs fine on its own.....It looks like its the plugin going out to read the xml dictionary spec from apple as HS is parsing the library contents....Look at the header of the xml file its contains the same url as the one in HS log file.
      D
        What version of iTunes are you running?
          10.0.1.22 with the latest itunes plugin.
