Global Cache Plug-In for HomeSeer
This topic is closed.
Steven,
I literally just got mine to work.
Check here http://board.homeseer.com/showthread.php?t=169464
I created a virtual COM Port 20 (need to reboot HomeSeer for it just to be sure) and I'm using a Script with a time trigger what I want sent.
The code in the script I'm using is pasted below, with my String Command going through the Parameters box (no ""s needed)
Sub Main(ShadeCmd)
hs.OpenComPort (20,"9600,N,8,1",1,"","")
hs.SendToComPort (20,ShadeCmd)
hs.closeComPort(20)
End Sub
Hope this helps.
MattK10
GC ports and nodes
GC uses port 4 for nodes 1-3. Port 5 for nodes 4-6. If you wanted to send an IR signal to node 2 for example it would look like this:
Sendir, 4:2, (then rest of cammand)
Cheeryfool just directed me to drule's IP/Serial plugin that can be found here: http://board.homeseer.com/showthread.php?t=169754 and it controls the GC100-12 Com ports with no effort when using it as a TCP-IP device.
He pointed it out on my other thread here, I also posted screenshots there: http://board.homeseer.com/showthread...=1#post1133044
Much easier than using port forwarding software!
