I am able to see and manage via the onQ web interface but I don't see where I can add devices to represent each Tstat so that I can easiliy adjust their settings. Is the only way to make changes to the Tstat is by script?
Example, I can create an event that looks for the change of setting on t-stat (Temp set point > than 65). But I am not able to pick a device and command using GUI to send a command to that Tstat to set temperature back to 64.
Is there a way to create thermostat devices within the main HomeSeer control system?
I am using the latest BETA version on an OnQ HMS 1100
Mark
Mark
