Attached is a zip file containing some source code in the C langage that I thought might be useful to Rick or someone, as it contains all the AES encryption stuff as well as ethernet com module. The code is GPL licensed, but can be used as an tool to gleen enough information to build a VB HomeSeer Plugin.
HAI Plugin Source Code
-Larry
A member of "The HA Pioneer Group", MyWebSite
Plugins:
VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
Hardware:
Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.Tags: None
It is much appreciated, albeit a little too late.
I have had to stop development on the plug-in for a little while so we can finish up HS 2, but once that is done I will get back to it. Just as I was setting it aside, HAI finally (almost 2 years late) sent me the DLL that they promised to do everything, so in theory I should not need this code. If the DLL blows though, then I will look at this - so thanks.Regards,
Rick Tinker (a.k.a. "Tink")
