Rick, been adding command lines to programming of Omni Pro II and I know previously you had mentioned it was not too nice to your plugin. Think I have only about 20 lines or so entered.
So I am seeing a lot of:
Performing Startup/Recovery Check of the System.
I can accept this as an after effect from running command lines in the OmniPro II.
Is there a way to disable the logging of this entity?
On another note (and I have asked this before but was just wondering) will you be doing anything to your plugin so that the time of the Omni Pro panel can be accessed and synced to HS?
