I have upgraded to Homeseer 2.0 (version 2.0.2041.0) and am trying to get my HAI plugin working (version 2.0.0.12). My panel is an Omni II with a serial connection. PC Access works fine with this panel from the same computer.
First problem is that it won't let me register the plugin. Under the "License" page I have clicked on "register manually" and entered the code from my confirmation e-mail. When I hit register it goes back to the default screen and still shows the plugin as unregistered. Is there a way to delete and reinstall the plugin without screwing everythgin up? Do I need a new code for HS 2.0?
Incidentially, running the "HAI_System_Check" script generates the following error message:
1/21/2006 6:40:26 AM - Error - Running script, script run or compile error in file: HAI_System_Check.txt424:Object required: 'hs.plugin(...)' in line 6 More info: Object required: 'hs.plugin(...)'
Thanks!
Thanks!
