Hello,
I was wondering if there is way to trigger an event off of a button. I have several of the touch panels around the house and would like to be able to set up several buttons that will cause Homeseer to run events. For example, I have Homeseer adjusting the thermstats during the day based on armed status and so on. I'd like to have a button that did the same thing. I want two buttons right now since I'm still installing switches but I can see the need for more later.
I want these two buttons to trigger two events, one will be called "Comfort Mode - Hot" and the other "Comfort Mode - Cold". These modes will adjust the thermostats up or down 2 degrees from the common setting in the case that my wife or myself just are not happy.
The problem is that I can't seem how to find how to trigger an event off of a HAI or On-Q button press. I can send a button press, just can't do anything if it's pressed on a panel.
If worse comes to worse, I guess I can set up something where the button press sets a light in the attic to 12% and then homeseer picks up on that and does an event and turns that light back off... kind of using some if then else logic triggered by the button press program that was created in PC Access.
