First off, thanks to Jayhawk & Rick. I had the same problem with Homeseer assigning one temp sensor twice. You guys were right, I had transposed an aux sensor for a temp sensor in the HAI PCAccess setup. Problem solved!!!
OK I got bored over the weekend & started from scratch with HS 2.1 & the old HAI plug-in. Sorry, but at least I'm in the right forum now. Found a new twist on the old above temp sensor issue. My Humidity & Temp sensors are zones 14 & 15. Homeseer has created Zone 014 & Zone 015 with codes ]14 & ]15. These are non-functional. At the bottom of the list it has also created Temp/Humidity sensor 014 & 015, codes ]75 & ]76, which do work. The difference is that last time the house code was different & the unit code correct. This time the house code is the same & the unit code different.
Also all my temp sensors have been re-created here (I have 4) where only the mis-labeled zone had been doubled before.
Paul
Paul
