I notice then sometimes when I create a HS event which uses a HAI trigger, I get a series of problems that follow. First, something seems to occur in HomeSeer, where from this point on, when I select "Events" from the HS top screen, a few events display, but the web page just quits in the middle. The first event with a HAI item seems to be the one getting stuck.
Next, when I shutdown HS, I get the following errors:
12/4/2006 12:36:44 PM ~!~HAI System~!~HAI Plug-In Shutting Down, Port Closed, Goodbye.
12/4/2006 12:36:48 PM ~!~HAI System~!~Get_Zone_Status experienced error 91, Object reference not set to an instance of an object.
12/4/2006 12:36:48 PM ~!~HAI System Error~!~Starting send/receive thread, exception: This property has already been set and cannot be modified.
12/4/2006 12:36:52 PM ~!~Database~!~Saving Devices...
12/4/2006 12:36:52 PM ~!~HAI System Error~!~Starting send/receive thread, exception: This property has already been set and cannot be modified.
And after the database saving stuff:
12/4/2006 12:37:01 PM ~!~Database Item~!~Event condition row enumeration for deletes failed: (5940) Object reference not set to an instance of an object.
12/4/2006 12:37:01 PM ~!~Database~!~Error: EventConditions update loop error (6320) 91, Object reference not set to an instance of an object.
Using the latest beta HAI plug-in. When I restart, all seems O.K. unless I again create or modify a HS event that is triggered by a HAI trigger.
