O.K. I used to have a Omni II and HomeSeer and both worked great together. I upgraded my Omni II to an OmniPro II and its been problems.
I have about 100 lines of code running on the OmniPro and interface it to HomeSeer. My problem is, many timers on the OmniPro seem to fail when HomeSeer is connected to the Omni.
Lets say I need something to occur a minute after something else on the OmniPro. I will set a Unit to be ON for 60 seconds. If I go to PC Access and monitor it, I'll see it count down 59, 58, 57, 56, 55, and then switch to ON. (This is an example, its usually random.) If I do the same WITHOUT HomeSeer connected, it works fine.
It got so bad that I sent the board back to HAI for repair. They checked it out, replaced all the memory, upgraded the FW to 2.14, but I still see the problem. Other HAI programming seems to run O.K. but timers are unreliable.
Anyone else see this?
