Random Unexplained HAI Thermostat Changes
This topic is closed.
    #31
    Hello Ross,
    I turned comms logging off last week. I happen to catch this on the HVAC link, I have only seen it a couple of times.
    Pete
    - Pete
    Auto mator
    HS4 Pro - Ubuntu 22.04 / Lenova Tiny M900 / 32Gb Ram
      #32
      Yeah... I think there's something seriously wrong with the way the plugin is working with thermostats at the moment. Just seems to be randomly doing strange stuff.
        #33
        No response to open ticket yet .....2 days...
        - Pete
        Auto mator
          #34
          Same issues here. I have two HAI RC-80s and the setpoints randomly jump up to 79 degrees every now and then. The other thing I've noticed is that if I stand in front of the thermostat and manually change the setpoint I appear to be fighting with a remote signal telling it to be at a different setpoint. As i push the up button the "remote" indicator goes away and my setpoint takes but within about 1/2 second the "remote" indicator is back on and the setpoint is much lower than where I set it.
          This problem really complicates matters for me because this is located in a mountain house that we rent out on the weekends. You can imagine the confusion on the renters part when they are fighting with the thermostat to get a setpoint.
          I've rolled back the HAI plugin to 2.0.0.19. I don't remember having these problems with that version.
          Pat
            #35
            Pat, let us know if rolling back to V2.0.0.19 helps.
            - Pete
            Auto mator
              #36
              At this time setting the high limit on the thermostat has temporarily solved the issue. I am also saving on my heating bills by keeping the uppper limit to 72.
              - Pete
              Auto mator
                #37
                After having rolled back to earlier version I haven't seen any of the random changes to the setpoint sent from the controller. I haven't actually been to the house so I'm not sure how it responds when standing in front of the t-stat and making manual changes.
                Pat
                  #38
                  So it looks like the beta version has a "glitch". I don't recall all of the advantages of the beta over the production version of the plugin but this one glitch causes very low WAF. I understand that all of the beta features cannot be tested at the same time and sometimes it takes some time for bugs to crop up. None the less these bugs should be addressed and not swept under the rug which I believe is occuring right now.
                  - Pete
                  Auto mator
                    #39
                    Interesting thing happened Christmas day. I had family over and was asked to turn down the thermostat. It was too warm at 72 in the house. I went to the thermostat and set it to 68. I sat and watched it a bit and it set itself back to 72 (as the remote icon kept flashing).
                    - Pete
                    Auto mator
                      #40
                      Tell the HAI plugin to ignore the Thermostat until it's fixed, otherwise it'll keep doing strange things.
                        #41
                        So far rolling back to the previous version seems to have done the trick for me. No more random changes and no problems standing in front of the stat making manual changes and having them revert to a random setting. I'm sticking with the older version until I'm certain the problems are resolved.
                        Pat
                          #42
                          Pat, thinking of going back to previous version more seriously now in that a similiar to HAI thermostat thing happened with my alarm a couple of days ago. It caused some issues....
                          - Pete
                          Auto mator
                            #43
                            My setup is pretty simple and mostly revolves around temperature (2 T-stats for heating, hot tub, outside air). I don't have any alarm set up on the house.
                            After having rolled-back I've had no problems at all. My t-stats have worked as expected (as opposed to before where they would randomly change setpoints).
                            Pat
