I know that the new HS3 plugin will only work with an Ethernet Omni panel but can you convert the Serial port on an old Omni II to ethernet to work with the plugin. I do not want to upgrade my panel just to go to HS3
Mike
I don't believe you can without changing the entire panel. Maybe others will correct me if I'm wrong.
Sent from my SCH-R970X using Tapatalk
68 Z-Wave Nodes, 175 Events, 359 Devices
Here I am still using Homeseer 2 / Serial HAI plugin concurrently with the new HS3 network plugin.
The above said you can configure the HS2 and HS3 to talk to each other via Jon00's script / application.
The last version of the serial plugin is working well these days and would be fine with your older panel as it was written in the early 2000's.
You can also DIY a simple serial plugin and integrate to HS3. Search over on CT. Someone did write an Arduino Sketch for serial connectivity to the HAI serial port. You could tweak it and use one of those tiny Arduino boards and DIY an interface to HS3.
Here I installed a TP-Link microrouter with two NICs, 802.XX and serial ports on it. I have tested the serial port to HAI panel pieces sending and receiving commands from the panel. Works fine. Only thing is that the Microrouter doesn't have enough stuff for running much and only runs at 400Mhz. I was able to create a very simple single page web interface that talked to the serial port on the panel and it worked fine. You can also configure it to do status polling the serial port for simple stuff (alarm triggers).
Or as Rob mentions you can just upgrade your Leviton OPII panel. Thinking the LTE panel would probably work for you.
The Omni LTe is a scaled down version of the popular OmniPro II and Omni IIe security & automation systems. The Omni LTe supports the following protocols and products: X-10, UPB, Omni-Bus, ZigBee, Vizia RF Z-Wave, Clipsal C-Bus, Dynalite, Coolmaster, KNX, HAI Hi-Fi, and HAI Hi-Fi 2. In addition to connections for security devices, thermostats, light switches, telephone and backup battery, the Omni IIe features five built-in serial ports for connection to additional control devices. The Omni LTe has an Ethernet port that allows connection to your home network. Use a tablet or smartphone inside or outside the home to turn on lights, turn down the TV volume, or adjust the temperature. The Omni LTe supports up to 32 zones of security, 4 thermostats, 4 rooms for lighting control (32 lights), and 4 access control readers.
I use HeidiSQL in Windows or Linux Wine. I also did get HAI PCA running in Wine just fine.
In Ubuntu Linux there is a whole bunch of applications that talk to mysql DB's. I have used both.
I like HeidiSQL mostly because I have been using it for a few years now in Wintel.
I am also running an HAI logger program which talks to the OPII logging all of its stuff to another mySQL db.
This program is currently running on my Homeseer 3 box in Ubuntu 14.04. Basically it just sends alerts, alarms and time sync information via email or whatever these days.
- Pete
Auto mator
HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104 HS4 Lite -
