HAI RC-80 Setpoint Commands
    I am new to HS2 and am starting up my System. I am not able to change my setpoints from HS2. Other commands appear to work. When i command the stat the log file records
    9/8/2008 8:54:38 PM - Warning - Failed sending Z-Wave command to device(s): House House Cooling Setpoint ([29)
    I have two z-wave units which are both lights. I guess I don't understand why commands are going to Z-Wave devices instead of my stat.
    (if they are)?
    Changing the setpoint at the stat DOES display correctly on refresh update.
    I am using HAI Plug In.
    If you are using Z-Wave you need to use the Z-Wave tstat plugin from the HomeSeer updater.
    -Rupp
      Thanks for your reply. Reading it I realized I may have not furnish enough information for valid troubleshooting.
      The Stat I have is a HAI RC-80 connected to an Omni LT. It continues to work perfectly as it has for two years. I am upgrading my front end to HS2 but will continue to use the LT and related HAI Program for standalone Fire & Security and HVAC. I would however like to write scripts for non critical applications therefore I would like to be able to set set points from HS2.
      Considering the above is the Z-tool Stat. Plug In still the possible solution?
      Thanks for service to this Board.
