Humidity zone
    Humidity zone
    I hooked up a humidity sensor on Zone 8 - I used the HAI PC access program to monitor readings and it looks great - proper reading and listed as a temp zone under my outside temp.
    I see HS startup log and show it sees a humidity sensor on zone 8
    I go into HS - plug-ins, HAI_System (HVAC) - shows correctly under Auxiliary temp and humidity sensors with good readings.
    I go to Status - HAI Zones - it is showing Secure, Disarmed- huh?
    An unrelated issue is I removed a temp sensor on zone 10 and it is eliminated in PC Access and I removed all the namings in HS - however, the status is showing -40 - I would expect it to say Secure, Disarmed or something besides a value because I removed the Temp setting in PC access.
    Using 2.3.0.19 HS and 2.1.2746.29695 HAI plugin
