HAI Volunteers & Features
    This being the first message of this topic I would like to create a list of current features, improvements and new features.
    Volunteers for testing and coding: Pete, IPItman, basshook
    1 - Ethernet/TCP connectivity
    2 - changing from the polling engine to the event driven mechanism in HAI's DLL.
    4 - Today the HAI plugin interface to the HVAC is simple. With some scripting you can do more. With a "module" of sorts you could probably emulate a self contained HVAC application tied to the connectivity of the thermostat to the panel.
    5 - I use the motion sensors connected to the panel. A faster real time response via HS to the panel's connectivity to the motion sensors would be nice.
    6 - today the panel has some ability for simple programming lines. Mostly HS can do all of this but it would be nice to have an interface in the plugin to directly access / change program lines.
    This is just a start but I can summarize the comments on this thread to this first posting and continue making one list.
    I moved the post to its own thread.
    <!-- / message --><!-- sig -->
    - Pete
    Auto mator
    HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
    6.10.0.104
    HS4 Lite -
