HAI Plugin concern with HSP
    Rick,
    Noticed something similiar with my XaP triggers a couple of weeks back. Looking at my HAI events it appears that they are not there. When I go to edit the event I see the trigger. It appears though that the trigger is working but I cannot change it.
    - Pete
    Auto mator
    HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
    6.10.0.104
    HS4 Lite -
    I've seen this before when the plugin has been updated and the conditions have changed. Try recreating some of the events to see if this solves the issue?
    -Rupp
      I've never seen this with the HAI plugin.
      Haven't updated the plugin nor have I changed any conditions.
      Tried to create a new HAI event and it didn't work.
      Same thing happened with XaP plugin. Not sure what Michael did to fix it though.
      - Pete
      Auto mator
      6.10.0.104
      HS4 Lite -
        Rick,
        Have you had a chance to look to see what might be wrong?
        UPDATE: Starring at it a while I think its OK the way it is. Seeing the "when" there makes it confusion but it is correct. It is a "when" statement though the "when" is coming after the condition instead of before the condition. The only variable is there and its either secure or not secure. The other issue mentioned (MCS XaP) I was not seeing the variables once chosen.
        - Pete
        Auto mator
        6.10.0.104
        HS4 Lite -
