Omni plugin won't work for us.
  • Omni plugin won't work for us.
    This is a new nearly un-programmed Omni2 Pro. We've only defined zones. When we try to run the plugin, we get this in the logs:
    2/2/2010 2:53:33 PM
    Updater
    Starting installation of updates
    2/2/2010 2:53:33 PM
    Updater
    Applying update: HAI Panel Plug-in
    2/2/2010 2:53:33 PM
    Updater
    Copying file: C:\Program Files\HomeSeer HS2\scripts\HAI_System_Check.txt
    2/2/2010 2:53:33 PM
    Updater
    Extracting files from zip file: WebHelp.zip
    2/2/2010 2:53:40 PM
    Updater
    Extraction Complete.
    2/2/2010 2:53:40 PM
    System
    Un-registering C:\Program Files\HomeSeer HS2\hspi_HAI.exe with Windows
    2/2/2010 2:53:43 PM
    Updater
    Copying file: C:\Program Files\HomeSeer HS2\hspi_HAI.exe
    2/2/2010 2:53:43 PM
    System
    Registering C:\Program Files\HomeSeer HS2\hspi_HAI.exe with Windows
    2/2/2010 2:53:45 PM
    Updater Warning
    File exists, not overwriting: C:\Program Files\HomeSeer HS2\Config\HAI_System.lf
    2/2/2010 2:53:45 PM
    Updater
    Installation of updates completed
    2/2/2010 2:53:45 PM
    Startup
    Restoring Device Status
    2/2/2010 2:53:45 PM
    Z-Wave
    :- :- :- :- :- :- :- :- Initializing Z-Wave Interface -: -: -: -: -: -: -: -:
    2/2/2010 2:53:45 PM
    Z-Wave
    Initializing Z-Wave Interface on COM port: 4 at 115K baud.
    2/2/2010 2:53:49 PM
    Warning
    In Z-Wave init, no response getting initialization information.
    2/2/2010 2:53:49 PM
    Z-Wave
    Z-Wave interface version: 0
    2/2/2010 2:53:49 PM
    Z-Wave
    Z-Wave interface node ID: 0, Home ID:
    2/2/2010 2:53:49 PM
    Z-Wave
    Found 0 Z-Wave nodes
    2/2/2010 2:53:49 PM
    Z-Wave Error
    (Init/Sync) Initializing Z-Wave Interface: Could not communicate with the interface to get the version.
    2/2/2010 2:53:49 PM
    Z-Wave
    2/2/2010 2:53:49 PM
    System
    Registering hs_compatibility.exe with Windows
    2/2/2010 2:53:51 PM
    Error
    Unable to initialize HomeSeer 1.x compatibility interface: Retrieving the COM class factory for component with CLSID {4B3C1F4A-4B61-4897-B13F-5DF3D40C7954} failed due to the following error: 80040154.
    2/2/2010 2:53:51 PM
    Startup
    Checking for available plug-ins
    2/2/2010 2:53:51 PM
    Plug-In
    Found plug-in: X10 CM11A/CM12U, version: 1.0.1.0
    2/2/2010 2:53:51 PM
    Plug-In
    Found plug-in: X10 CM15AUSB, version: 1.0.0.3
    2/2/2010 2:53:51 PM
    Error
    Cannot access plug-in (may need to be re-installed): HSPI_HAI.HSPI -> Object variable or With block variable not set.
    We're not sure how to proceed. Exact firmware version is still unclear, but should be 3.x as we bought this Omni last Summer.
    -KP
    This is a HomeSeer error and not a plugin error. What version of HomeSeer are you running? Try doing a repair on your HomeSeer install if you are running the lastest version of HomeSeer.
    -Rupp
      OK...I deleted the plug-in and downloaded the Beta version and it worked, but can't go any further:
      2/3/2010 9:05:52 AM
      Plug-In
      Interface HAI_System is running as a trial, 30 days remaining.
      2/3/2010 9:05:52 AM
      Plug-In
      Initializing Plug-in: HAI_System
      2/3/2010 9:05:52 AM
      HAI System Warning
      hspi_HAI.ini does not exist - the plug-in must be configured using the configuration web page.
      2/3/2010 9:05:52 AM
      HAI System Warning
      COM port for the plug-in is not set.
      2/3/2010 9:05:52 AM
      HAI System Warning
      Panel Code for the plug-in is not set.
      2/3/2010 9:05:52 AM
      HAI System
      Exception in DecryptNumber: Length of argument 'String' must be greater than zero.
      2/3/2010 9:05:52 AM
      HAI System
      Encrypt/Decrypt error message: Error during CryptDecrypt(D).
      2/3/2010 9:05:52 AM
      HAI System
      HAI Plug-In Version 2.1.2746.29695
      2/3/2010 9:05:53 AM
      HAI System
      HAI Error: Plug-In Needs To Be Configured. Plug-In functionality has been disabled until this is corrected and HomeSeer is restarted.
      2/3/2010 9:05:53 AM
      Plug-In
      Finished initializing plug-in HAI_System
      -KP
        Not sure if this is progress or not. Where do we enter the IP address? I think the com port info isn't correct...
        2/3/2010 9:59:39 AM
        HAI System
        Opening COM port and resuming normal operation after processing events from the panel... Please wait.
        2/3/2010 9:59:57 AM
        HAI System
        2/3/2010 10:01:53 AM
        Device Control
        Device: Dining Room Dining Room Spots (B15) ON
        2/3/2010 10:02:00 AM
        Device Control
        Device: Dining Room Dining Room Spots (B15) OFF
        2/3/2010 10:02:29 AM
        Device Control
        Device: Kitchen Kitchen Counter Lights (C7) ON
        2/3/2010 10:05:00 AM
        HAI System
        Checking special devices, creating any that need to be created....
        Warning
        'status' property on device HAI Zones Zone 001 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 002 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 003 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 004 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 005 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 006 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 007 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 008 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 009 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 010 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 011 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 012 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 013 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 014 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 015 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 016 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 017 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 018 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 019 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 020 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 021 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 022 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 023 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 024 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 025 was accessed - this property has been deprecated and should not be used.
        Warning
        'status' property on device HAI Zones Zone 026 was accessed - this property has been deprecated and should not be used.
        2/3/2010 10:05:28 AM
        HAI System
        -KP
          Did you check the Setup > Interfaces tab for the plugin and select configure?
            Yes.
            We're using ethernet to connect (hopefully...) and are not sure how to enter the ip address...apparently...
            -KP
            edit: Running the latest everything...including beta HAI plugin.
              What are you using ethernet to connect to?
              Is your HAI Panel connected to HS via a serial port? Think you mentioned that it is eh?
              I am guessing that you can see the configuration page and have configured the panel to the correct serial port eh?
              The currently used HS plugin (both standard and beta) only talk to the panel via a serial port.
              The HAI panel IP configuration is set up via an HAI console initially from scratch.
              - Pete
              Auto mator
              HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
              HS4 Lite -
                The HomeSeer plugin will not work with eithernet connections if my memory serves me correctly.
                  I did? I hope I didn't say we're connecting with rs-232...we're trying with tcp/ip...
                  I thought I'd picked up that tcp/ip was working in the latest firmware/plugin. Regardless of how unlikely the scenario is, I COULD be wrong...
                  Right now the PC and the Omni are in different rooms. We're migrating an install on to a new PC and trying to add this new Omni.
                  If TCP/IP is NOT working, then...never mind...we'll have to reconfigure...
                  -KP
                    In this post:
                    http://board.homeseer.com/showpost.p...4&postcount=99
                    it was mentioned that TCP/IP was working...
                    No?
                    We've set an ip address on the Omni panel and our router must have detected it with some kind of upnp, 'cause it suddenly detected it...
                    -KP
                      A new HS plugin capable of using the new HAI protocols and IP would open a new chapter to utilizing HS with the HAI Omni Pro Panels.
                      My mention of firmware and IP connectivity was only related to HAI OmniPro II firmware.
                      - Pete
                      Auto mator
                      HS4 Lite -
                        I have been jacking with this for hours!
                        New PC with built in serial port.
                        We can't get past "could not communicate with panel". I'm starting to get very pissed.
                        Feeling like a red-headed step-child. (My apologies to red-headed step-children)
                        What the heII is wrong?
                        Here's a snip of the log.
                        Please help!
                        -KP
                        6/15/2010 9:58:22 PM:079102.34 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:22 PM:079102.34 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:22 PM:079102.34 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:22 PM:079102.34 ~tmrStatusCheck Timer - Rock_n_Roll false due to failure of HAI_Login_Panel. (1) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:22 PM:079102.34 ~Exiting tmrStatusCheck_Timer (2) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:22 PM:079102.84 ~Entering tmrStatusCheck_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:22 PM:079102.84 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:22 PM:079102.84 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:22 PM:079102.84 ~Entering HAI_Login_PanelStat ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:22 PM:079102.84 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:22 PM:079102.84 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:22 PM:079102.95 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.08 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Exiting HAI_Login_PanelStat (Login Failure) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.09 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.11 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.11 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.20 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.33 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.36 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.36 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.36 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.36 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.36 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.36 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.36 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.36 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.36 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.36 ~tmrStatusCheck Timer - Rock_n_Roll false due to failure of HAI_Login_Panel. (1) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.36 ~Exiting tmrStatusCheck_Timer (2) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.86 ~Entering tmrStatusCheck_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.86 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.86 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.86 ~Entering HAI_Login_PanelStat ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.86 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.86 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:23 PM:079103.95 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.08 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.11 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.11 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.11 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.11 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.11 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.11 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.11 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.11 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.11 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.11 ~Exiting HAI_Login_PanelStat (Login Failure) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.11 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.13 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.13 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.13 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.20 ~ReadFromPanel got a stray character (SOM=False): F8 ~VARS~ ----------,IQ=0,OQ=1
                        6/15/2010 9:58:24 PM:079104.20 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.33 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.34 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.34 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.34 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.34 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.34 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.34 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.34 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.34 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.34 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.34 ~tmrStatusCheck Timer - Rock_n_Roll false due to failure of HAI_Login_Panel. (1) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.34 ~Exiting tmrStatusCheck_Timer (2) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.84 ~Entering tmrStatusCheck_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.84 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.84 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.84 ~Entering HAI_Login_PanelStat ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.84 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.84 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:24 PM:079104.95 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.08 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Exiting HAI_Login_PanelStat (Login Failure) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.09 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.11 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.11 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.20 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.33 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.36 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.36 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.36 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.36 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.36 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.36 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.36 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.36 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.36 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.36 ~tmrStatusCheck Timer - Rock_n_Roll false due to failure of HAI_Login_Panel. (1) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.36 ~Exiting tmrStatusCheck_Timer (2) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.45 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.86 ~Entering tmrStatusCheck_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.86 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.86 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.86 ~Entering HAI_Login_PanelStat ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.86 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.86 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:25 PM:079105.95 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.08 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Exiting HAI_Login_PanelStat (Login Failure) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.11 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.13 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.13 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.20 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.33 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.34 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.34 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.34 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.34 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.34 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.34 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.34 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.34 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.34 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.34 ~tmrStatusCheck Timer - Rock_n_Roll false due to failure of HAI_Login_Panel. (1) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.34 ~Exiting tmrStatusCheck_Timer (2) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.84 ~Entering tmrStatusCheck_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.84 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.84 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.84 ~Entering HAI_Login_PanelStat ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.84 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.84 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:26 PM:079106.95 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.08 ~ReadFromPanel got a stray character (SOM=False): 10 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Exiting HAI_Login_PanelStat (Login Failure) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.09 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.11 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.20 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.33 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.36 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.36 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.36 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.36 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.36 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.36 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.36 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.36 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.36 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.36 ~tmrStatusCheck Timer - Rock_n_Roll false due to failure of HAI_Login_Panel. (1) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.36 ~Exiting tmrStatusCheck_Timer (2) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.86 ~Entering tmrStatusCheck_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.86 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.86 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.86 ~Entering HAI_Login_PanelStat ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.86 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.86 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:27 PM:079107.95 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.08 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Exiting HAI_Login_PanelStat (Login Failure) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.11 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.13 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.13 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.20 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.33 ~ReadFromPanel got a stray character (SOM=False): 10 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.34 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.34 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.34 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.34 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.34 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.34 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.34 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.34 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.34 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.34 ~tmrStatusCheck Timer - Rock_n_Roll false due to failure of HAI_Login_Panel. (1) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.34 ~Exiting tmrStatusCheck_Timer (2) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.45 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.86 ~Entering tmrStatusCheck_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.86 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.86 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.86 ~Entering HAI_Login_PanelStat ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.86 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.86 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:28 PM:079108.95 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.08 ~ReadFromPanel got a stray character (SOM=False): 10 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Exiting HAI_Login_PanelStat (Login Failure) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.11 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.13 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.13 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.20 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=1
                        6/15/2010 9:58:29 PM:079109.20 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.33 ~ReadFromPanel got a stray character (SOM=False): C0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.34 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.34 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.34 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.34 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.34 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.34 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.34 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.34 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.34 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.34 ~tmrStatusCheck Timer - Rock_n_Roll false due to failure of HAI_Login_Panel. (1) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.34 ~Exiting tmrStatusCheck_Timer (2) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.45 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.84 ~Entering tmrStatusCheck_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.84 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.84 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.84 ~Entering HAI_Login_PanelStat ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.84 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.84 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:29 PM:079109.95 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.08 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.09 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.09 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.09 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.09 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.09 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.09 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.09 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.09 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.09 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.11 ~Exiting HAI_Login_PanelStat (Login Failure) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.11 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.11 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.11 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.11 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.20 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.33 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.36 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.36 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.36 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.36 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.36 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.36 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.36 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.36 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.36 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.36 ~tmrStatusCheck Timer - Rock_n_Roll false due to failure of HAI_Login_Panel. (1) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.36 ~Exiting tmrStatusCheck_Timer (2) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.45 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.58 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.70 ~ReadFromPanel got a stray character (SOM=False): C0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.86 ~Entering tmrStatusCheck_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.86 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.86 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.86 ~Entering HAI_Login_PanelStat ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.86 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.86 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:30 PM:079110.95 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.08 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.11 ~Received garbled or no message from the panel - discarding. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.11 ~Exiting Send_Receive (9) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.11 ~Interface is being reset due to value returned from Read_from_HAI being too short in HAI_Login_Panel. ~VARS~ --------P1,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.11 ~Entering Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.11 ~Entering HAI_Polling_Timer to set to False currently it is True ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.11 ~Exiting HAI_Polling_Timer ~VARS~ --------P0,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.11 ~Interface Reset: Rock_n_Roll is false, setting retry timer. ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.13 ~Exiting Reset_Interface ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.13 ~Exiting HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.13 ~Exiting HAI_Login_PanelStat (Login Failure) ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.13 ~Entering HAI_Login_Panel ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.13 ~Entering HAI_Polling_Timer to set to False currently it is False ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.13 ~Exiting HAI_Polling_Timer ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.13 ~Entering Send_Receive ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.20 ~ReadFromPanel got a stray character (SOM=False): 0 ~VARS~ ----------,IQ=0,OQ=1
                        6/15/2010 9:58:31 PM:079111.20 ~Sending (Serial): 5A-5-20(PANEL LOGIN)-1-1-1-1-11-FE ~VARS~ ----------,IQ=0,OQ=0
                        6/15/2010 9:58:31 PM:079111.25 ~Entering ShutdownIO ~VARS~ ----------,IQ=0,OQ=0
                          What's the first few lines of your HAI. Here is mine with the panel code removed.
                          [hspi_HAI]
                          COMPort=10
                          PanelModel=16
                          PanelCode=XYZ
                          Shut down the interface. Enter you panel code in the INI file and save the file. The panel code gets encrypted so it will become a "hash" of characters.
                          - Pete
                          Auto mator
                          HS4 Lite -
                            UUUgggghhhh
                            Sorry.
                            The new (refurbished) PC decided not to boot up. Won't post.
                            I'm going to have to swap it out for another unit.
                            I'll get back with you.
                            -KP
