I am not sure at what point this happened, but I no longer can change any values in my HAI panel from HS. It can READ values no problem, but neither webpage control buttons, nor actions in the events, nor scripting functions will change units or output values in the panel. I do have the latest HAI firmware 3.3d, HSPro version 2.4.0.3, HAI plugin version 2.1.2746.29695. Any hint will be greatly appreciated, thanks.
Problem sending commands
No errors. HS behaves like it did the job, however the values remain unchanged on the panel, and when HS reads it back, it gets the old values. When I execute a script command, the result is False (unsuccessful). Here is my test code
res=hs.plugin("HAI_System").UnitStatus(388)
hs.writeLog "HAI", "Unit status " & res
res=hs.plugin("HAI_System").HAI_Unit_Off(388)
hs.writeLog "HAI", res
This is HS log
3/14/2010 6:10:28 AM ~!~HAI~!~Unit status On
3/14/2010 6:10:28 AM ~!~HAI~!~False
I am still unable to send commands to the panel, I looked at the HAI plugin log and don't see anything that would indicate a command. The log is full with STATUS messages and sometimes has UNIT STATUS followed by Neagtive Acknowledge, but I cannot tell if this is the log of my HAI trigger. Should I log a help desk ticket?
Have you tried watching the HAI panel in PCAccess while you send commands over to it?
If you want I can try your code - have to modify it a bit for my panel though.Last edited by Pete; March 23, 2010, 10:41 PM.- Pete
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X - HSTouch on Intel tabletop tablets
HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104
HS4 Lite -X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Smartthings hub, Hubitat Hub, and Home Assistant
Originally posted by Pete View PostHave you tried watching the HAI panel in PCAccess while you send commands over to it?
I've been using it with HSPro beta .26 / HAI plugin / FW 3.2D / and its working for me.- Pete
Checked out your script statements and worked for me:
Here is the log and event
3/23/2010 11:28:26 PM Event Event Trigger "Test HAI 1"
3/23/2010 11:28:26 PM Event Running script and waiting: &hs.plugin("HAI_System").HAI_Unit_On(17)
3/23/2010 11:28:26 PM Event Running script and waiting: &hs.writeLog "HAI", "Unit status " & hs.plugin("HAI_System").UnitStatus(17)
3/23/2010 11:28:26 PM HAI Unit status On
3/23/2010 11:29:03 PM Event Event Trigger "Test HAI 2"
3/23/2010 11:29:03 PM Event Running script and waiting: &hs.plugin("HAI_System").HAI_Unit_Off(17)
3/23/2010 11:29:04 PM Event Running script and waiting: &hs.writeLog "HAI", "Unit status " & hs.plugin("HAI_System").UnitStatus(17)
3/23/2010 11:29:04 PM HAI Unit status Off
