I added a zone expansion module to my HAI Omni LT today in addition to doing some re-wiring for the zones and thermostat. I removed the zone resistors and re-wired the thermostat. I dont believe these changes have anything to do with the problem I'm seeing but wanted to note them just in case.
HomeSeer (2.4.0.11) is now crashing when I have the HAI plugin (2.1.2746.29695) enabled. I tried disconnecting the expansion module but I am still having the problem. I did not restart the panel after removing the expansion module.
When I disable the HAI plugin and restart HomeSeer it does not crash. When I re-enable the HAI plugin, HomeSeer will start and then the last log entry I see is:
11/1/2010 1:12:28 AM - HAI System - --- Starting global update of system at: 1:12:28 AM
then about 30-60 seconds later, HomeSeer crashes and I see this in the application event log:
Log Name: Application
Source: Application Error
Date: 11/1/2010 1:29:07 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: braino
Description:
Faulting application name: HomeSeerService.exe, version: 2.4.0.11, time stamp: 0x4b673f83
Faulting module name: KERNELBASE.dll, version: 6.1.7600.16385, time stamp: 0x4a5bdaae
Exception code: 0xe053534f
Fault offset: 0x00009617
Faulting process id: 0x%9
Faulting application start time: 0x%10
Faulting application path: %11
Faulting module path: %12
Report Id: %13
Could someone please help me troubleshoot this issue?
thanks,
Dan
Event ID: 1000
Level: Error
Keywords: Classic
User: N/A
Computer: braino
Description:
Report Id: %13
thanks,
Dan
