HAI Zone reading issue - deprecated
    Hi, I am moving Homeseer to a new pc. Moving the config etc. files as read about in these posts wasn't working very well for me so i started fresh with a clean install. v 2.5.0.1. Got my HSphone working again got my ocelot working . HAI is giving be this log message at startup: OmniproII with v3 firmware:
    <TABLE border=0 cellSpacing=2 cellPadding=0 width="100%"><TBODY><TR><TD class=LOGDateTime0 noWrap align=left>2/27/2011 2:53:19 PM </TD><TD class=LOGType0 colSpan=3 align=left>Warning </TD><TD class=LOGEntry0 colSpan=8 align=left>'status' property on device HAI Zones Zone 1 (1) was accessed - this property has been deprecated and should not be used</TD></TR></TBODY></TABLE>
    I'm getting hundreds of these, in gold, one for each HAI unit and device and flag etc.
    The plug-in seems to be working, monitoring zone and unit status as it should. This is with the beta, but this afternoon i've tried both versions with the same effect.
    Whats up? Should i just ignore it ?
    Paul
    It would appear that this issue does not re-appear on subsequent start-ups. Must have something to do with the unit creation process.
    Paul
      I have the following section in the general setup page configured as follows. I also have errors upon startup with the HAI configured UPB and Z-Wave lighting units but it doesn't affect their use.
      3/1/2011 11:23:10 AM HAI System House Code Extended (D): Unsupported (7) Please provide this information to HomeSeer Technologies.
      3/1/2011 11:23:10 AM HAI System House Code Extended (C): Unsupported (5) Please provide this information to HomeSeer Technologies.
      The "units" set up is now really a "hodgepode" mix of X10 (still), UBP (custom HAI configured) and Z-Wave (still playing with). I'm not finding the GE Z-Wave any better in quality than the previously mentioned MFG switches. (IE my testing with the Z-Wave appliance modules failed again with the GE switches throwing the breakers).
      - Pete
      Auto mator
      HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
      6.10.0.104
      HS4 Lite -
        Thanks Pete,
        I've had no more issues here. I do have another question. Like you I have a mix of UPB and old X-10 devices. I have set the UPB devices up using Upstart. My HAI panel doesn't keep track of the devices very well with this configuration.
        Does Homeseer monitor the HAI configured devices? I presumed not since HS requires the Upstart export file. Is there an advantage to either of these setups?
        I've never been crystal clear on the differences between the two setup configurations and have read Worthingtons setup presentation ppt several times.
        Paul
