11/2/2011 4:16:21 PM - HAI System - Get_Multi_Zone_Status experienced error getting zones 387 thru 387 : 6, Arithmetic operation resulted in an overflow.
I just added a second HW expansion unit and found a couple of frustrating issues. First the polling has gotten considerably slower. I have a humidty sensor tied to a skylight. The timing was very consistent until I added the expander. I've changed the polling rate, the time interval of the script but no luck. I do get this failure now and it maybe correlated but that also unclear since I don't know what it means nor does it occurr all the time.
Question:
1. what is the error and how can I fix it.
2. how do I speed up the system polling (its always been slower then desirable but I've lived with that). 64bit OS (have but haven't installed Win7)?, faster hardware, better interface to the Omni Pro II?
3. I'm using the hai .net plugin is the other the original Beta version? I have several extended temp sensors
4. I just got the pro version (haven't installed it yet) is that going to help?
Question:
