When I first setup the HAI plugin I set it to port 9 like it says on the plug. There's 8 port plugs and the first one starts at 3 so I should have set HAI to port 7.
Anyway now when I try change the port in config I get "The webpage cannot be found" and below is what I comes up on the log. I have deleated the HAI file in the root and reinstalled the plugin and I get the same thing when I try to config the plugin. Is there a way to delete the file or uninstall it so it dose not keep port 9 when I install it?
Thanks Craig
12/13/2011 5:58:58 PM - HAI System - About to initialize HAI System on COM9
12/13/2011 5:58:58 PM - HAI System - HAI Error: Failed to initialize HAI COM9 port. (Security Init)
12/13/2011 5:58:58 PM - COM Plugin - InitIO error:
12/13/2011 5:58:58 PM - COM Plugin Error - Error initializing Custom Interface: Failed to initialize HAI COM9 port. (Security Init)
12/13/2011 5:58:58 PM - Error - Initializing interface: HAI_System->Failed to initialize HAI COM9 port. (Security Init)
Thanks Craig
