I had to load a new PC with Homeseer and loaded the newest HAI plugin. My thermostats showed "comm error", so I dug through the posts and found it was best to use the older plugin (not .NET). I renamed the exe and dll files and reinstalled the older plugin. HS starts up, connects to the panel (or so it seems) and the last message is "getting panel configuration information". If I go to the HAI_System web setup, it displays, but then pops up "Run-time error '438': Object doesn't support this property or method".
Do I need to completely remove the .NET plugin somehow and start fresh? If so... how?
