HAI over XAP
    HAI over XAP
    I just stumbled across this: http://www.iranger.com/page4/files/o...uritySyst.html
    It appears to access the hai Omni over Ethernet. I'm wondering if it would be possible to use this to talk to the hai system from homeseer. It's been years since i've messed around with XAP or XPL but I still fundamentally like the idea.
    Any thoughts?
    Very nice!
    I played a bit with XPL relating to a Chumby touchscreen interface to Homeseer and it worked just fine and was quick a few years back.
    Damage utilizes XPL extensively.
    - Pete
    Auto mator
    HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
    6.10.0.104
    HS4 Lite -
      So it is official that HAI alarms are not supported in HomeSeer 3 - http://cwsdemo.intergraphgovsolution...3PluginStatus/
      Any chance of finding someone to write a good plugin for this?
        I would, but that hardware is way too cost-prohibitive to even get a development system up
        68 Z-Wave Nodes, 175 Events, 359 Devices
          I bought my OmniProII system off of ebay for <$100. It was actually an OnQ 1100 but I sent it back to HAI for a firmware change and now it is a fully functional OmniProII.
          Bit of hassle but it turned out to be a pretty cheap solution.
            What a great deal.
            Here I had a spare OmniproII and showed the system to a neighbor in Florida. I took my legacy OPII and put that one in Florida and purchased the new style with upgradable flash for up north.
            That said I installed it in her house; installation was gratis as I have known her many many years.
            The impetus was her x causing some issues.
            - Pete
            Auto mator
            6.10.0.104
            HS4 Lite -
              Rob,
              Say you did get an OmniPro2 that fell from the sky gratis like; would you write a plugin?
              The base OPII is an all included do what. You just add the controllers for lighting stuff, et al.
              - Pete
              Auto mator
              6.10.0.104
              HS4 Lite -
                Originally posted by Pete View Post
                Rob,
                I sure would! I would even pay for one that was ~200 or so...
                  Good news Rob.
                  Personally I like Elk a lot too.
                  Mostly went though to HAI was because of the tiny footprint.
                  I sent an email to you.
                  - Pete
                  Auto mator
                  6.10.0.104
                  HS4 Lite -
                    I am a 100% UPB user with the HAI OmniPro II as my controller. I have three HAI thermostats connected through my Omnipro II. I would be willing to pay for a plugin, help pay for a system to get someone who will support HAI, etc. Without HAI support, HS3 is useless to me, and the HAI support in HS2 did not handle the thermostats reliably. The fans on the A/C units randomly cycling on/off in the night and setting the cold setpoint to 40 degrees F was more then the wife could handle.
                      The before the dot net version of the HAI OPII serial plugin does not do this with my one Omnistat 2 thermostat or my older HAI RC-80.
                      That said I have tried and fallen back on the older plugin (2.0.0.19) a few times in the last 10 years.
                      But today with the newest HAI OPII firmware (3.11d) and the older plugin (2.0.0.19) ; the plugin is working but not ideally with some comm issues and not recognizing stuff I have connected.
                      Relating to a "new" plugin; I have some ideas about methodology or approach of said plugin.
                      I have a list posted of Homeseer users and will add your name to it.
                      - Pete
                      Auto mator
                      6.10.0.104
                      HS4 Lite -
                        Pete,
                        Thank you so much for the HAI plugin tip. I never thought to go back to the "old" one. No more thermostat issues and I'm back on track in using HStouch and HS2. I do have a weird security system issue. The 2.0.0.19 plug in gives me a security status of "Armed UNKNOWN 112 (Delay)" when the alarm is unarmed. When I use the API to query, it returns a value of 100 which is not listed int he API docs a a valid value. I tried using a virtual device and a script to fake the 100 value as unarmed, but the API will not let me arm the security system when it thinks it is already armed. It is more acceptable ot not be able to manage the alrm than to have the thermostats changing ont heir own.
                        Thanks again for the tip!
                        Guy
                          Guy,
                          Have you seen the poll for a new HS3 HAI plugin?
                          - Pete
                          Auto mator
                          6.10.0.104
                          HS4 Lite -
                            Pete,
                            I see it now. I had given up on an HS3 plug-in so I'm glad you pointed it out to me. Looks like it'll be a while before UPB or HS3 are supported, so I'm hard at work implementing a HS2 deployment. When HS3 has the components I need I'll make the switch. Thanks!
                              Pete/Rob,
                              If I can contribute in any way let me know. I am willing to provide some hardware or cash to get this moving.
                              Glenn
