Guest Security??
  • Guest Security??
    Does anyone know of a fix that will prevent Guest access to the HAVC and Security screens? The fact that a guest can view and change these pages is a bit of a problem. In fact, it would be great if I could block this info from even going to HomeSeer. In HomeSeer, you can edit most web pages, but this doesn't seem to be the case with HAI pages.
    As a workaround until I put something in the plug-in itself, you can create or edit links.htm to do a check of the user or even prompt for a username and password if you want to have your own user security. The HAI plug-in generated pages still load the default HomeSeer pages.
    Rick Tinker
    HomeSeer Technologies
    Rick Tinker (a.k.a. "Tink")
      I should note here that the most recent version of HomeSeer fixed this problem by not allowing guest access to plug-ins. Thanks. That is a good enough solution for me.
