Problems Rick.
Upgraded to .94 last night, and noticed HS performance went into the dumps. Had a chance to look into now and found the following info in the log.
12/22/2003 1:19:56 AM~!~HAI System~!~HAI Plug-In Version 1.0.94
12/22/2003 1:19:56 AM~!~HAI System~!~About to initialize HAI System on COM1
12/22/2003 1:19:57 AM~!~HAI System~!~Security code is number 0, which has a level of Invalid Code
12/22/2003 1:19:57 AM~!~HAI System~!~Panel Model: 4 (Omni Pro) with Panel Software Version: 1.8
Everything seems to be fine until I kick off a button through HS, at which point I start getting this.
12/22/2003 1:29:10 AM~!~HAI System~!~Performing Startup/Recovery Check of the System.
12/22/2003 1:29:12 AM~!~HAI System~!~Performing Startup/Recovery Check of the System.
12/22/2003 1:29:15 AM~!~HAI System~!~Performing Startup/Recovery Check of the System.
12/22/2003 1:29:18 AM~!~HAI System~!~Performing Startup/Recovery Check of the System.
12/22/2003 1:29:20 AM~!~HAI System~!~Performing Startup/Recovery Check of the System.
12/22/2003 1:29:21 AM~!~Warning~!~I/O interface is down, restarting ...
12/22/2003 1:29:22 AM~!~HAI System~!~HAI Plug-In Version 1.0.94
12/22/2003 1:29:22 AM~!~HAI System~!~About to initialize HAI System on COM1
12/22/2003 1:29:23 AM~!~HAI System~!~Security code is number 0, which has a level of Invalid Code
12/22/2003 1:29:24 AM~!~HAI System~!~Panel Model: 4 (Omni Pro) with Panel Software Version: 1.8
12/22/2003 1:29:36 AM~!~HAI System~!~Performing Startup/Recovery Check of the System.
12/22/2003 1:29:57 AM~!~HAI System~!~All HAI Items and Units are Up-To-Date. Triggers and Conditions are now active.
After the :21 warning I used task manager to shutdown the plugin, after which it automatically restarted itself and everything is fine until the next button push. I also noticed that CPU usage which normally runs between 5% - 15% jumps all the way to 85% - 100% when the recovery routine stuff is going on.
Any thoughts? Am I getting bit in the posterior again by my large system? I'm going back to .66 for the moment so everything is working.
My system is described in my profile.
