I think the issues may be two fold. First I have seen, and I have had a lot of problems getting these connected and communicating right. Once they are connected and communicating right I have no real issues. But... I do not use HS to set my temps, I use HS only to read current settings and twice a day change the fan settings. this works 99.4% of the time. I can see where people would have issues trying to adjust the temp with HS throughout the day as the sript will always timeout if you run it twice or on top of itself.
I have helped stop some of this in my system by setting the poll rate to 4 minutes, I would have gone longer but after 5 the outside temp on the display will timeout.
The problem is I cannot stop HS from polling the Tstats and the hs.isscriptrunning command does not work on detecting itself. So you get the script running twice and timing out.
Scott
Scott
