OK I have conneted my rc-100 tstat in the following way.
9-pin RS232 FM plug
Pins:
8-7 Jumpered together.
1-6-4---Yellow Wire (1,6,4 Jumpered together)
3----Green Wire
2----Red Wire
5----Black Wire
I am using the rc100 script. i have tried COM 1,2,3,4 all of wich i have tested on other devices and they work fine. I plan to use COM 4 as my Port of choice. as the other ports 1 through 3 are used by other HA devices.
The HS log shows
Timeout: numbers
and
Failed to open com port 4
The tstat is configured to address 1
communications mode 0 which is 300 baud, RS232 MODE
Have i missed somthing is my cable connections correct?
Andrew
9-pin RS232 FM plug
Pins:
3----Green Wire
2----Red Wire
5----Black Wire
The HS log shows
Timeout: numbers
and
Andrew
