Rick...Any Ideas?
  • Rick...Any Ideas?
    Trying to use mainlobby to control alc devices.
    Get this error...
    Client: [myClient1] Cmd: [ex:unit7On] Reply: [Error in command, check syntax.] 31 characters
    Any ideas?
    Josh
    No idea at all! It just says that the command failed due to a potential syntax problem.
    Can somebody show me the exact call to the HAI/OnQ plug-in that is being made to control the ALC device?
    The prototype for the call is:
    HAI_Unit_On(unit as integer) as boolean
    So in a script, using unit 123 as an example, it might look like this:
    bResult = hs.plugin("HAI_System").HAI_Unit_On(123)
    if not bResult then
    hs.writelog "ML-HAI","It failed!"
    end if
    Of course you need to substitute HAI_System and HAI for OnQ if you are using the OnQ plug-in.
    Rick Tinker (a.k.a. "Tink")
