Attached is a sneak peak at the plugin; a work in progress.
Leviton HAI Homeseer 3 Plugin Sneak Peak
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X - HSTouch on Intel tabletop tablets
HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104
HS4 Lite -X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Smartthings hub, Hubitat Hub, and Home AssistantTags: None
ETA relating to plugin depends on the sign off of the beta testing.
Note that first gen of the plugin will reside in Linux only.
A milestone yesterday.
- HAI HS3 plugin Updater works
Next steps relate to
- independent running of the plugin on Linux either on same Linux HS3 box or autonomous Linux device.
- creating a running image on an SD card that you can utilize on a Raspberry Pi.
- providing running plugin SD and Raspberry Pi to plugin contributors.
Any comments?Last edited by Pete; November 10, 2013, 10:47 AM.- Pete
Bumping this post to the top.- Pete
