OK. I have tried bypassing the webx and different comports and comport settings with no change what so ever.
JDS for HomeSeer 2.1 BETA
This topic is closed.
Apologies to "Agent J"
Troops, I do apologize for my earlier diatribe. I lost my cool. At least I am willing to admit my error. Sorry about that. Nonetheless, "Agent J" kept plugging away in spite of all the slings and arrows being thrown at him from many directions. Under Plugin 12SEP06, everything I need now works (e.g., Digital Inputs, Flags over 99, Relays under 41, & Variables) both ways for which I am exceedingly grateful. I have not checked ADCs, IRs, or Timers because I left that functionality with SG.
There are easy work arounds to handle things connected to SG via an RS-485 Hub so I hesitate to even suggest any further changes to the now (for me at least) stable and functioning SG Plugin. It has indeed been a long slog but the end result (i.e., smoothly functioning HS <-> SG communication) was well worth the effort. Thanks again, "Agent J"!
Matt have you tried?
When you go to the Interface tab under setup and you view the enabled and disabled buttons for the SG plugin, are both the x10 and other columns enabled.
If the other column is not enabled it will cause the plugin not to communicate flags and relays.
Hope this is the problem
Juan
Originally posted by jvaldesWhen you go to the Interface tab under setup and you view the enabled and disabled buttons for the SG plugin, are both the x10 and other columns enabled.
Juan
No Lone Ranger
Don't be too hard on yourself. Now that Juan points it out I realize I should have mentioned it to you too since early on I did the same thing. Others (including yours truly) have overlooked other rather obvious stuff. It's not like we have a detailed User's Manual. We have to rely on each other for help. Glad you got things going!
Originally posted by Cairndhu1Don't be too hard on yourself. Now that Juan points it out I realize I should have mentioned it to you too since early on I did the same thing. Others (including yours truly) have overlooked other rather obvious stuff. It's not like we have a detailed User's Manual. We have to rely on each other for help. Glad you got things going!
Congratulations, Matt. I know that feeling all too well - that odd combination of both disgust and relief when you finally figure out why the damned thing wouldn't work. I just popped a beer in your honor - but I have to drink it because you're not here.Here's to ya.
With HS, I have learned, and relearned, again and again and again that when it works for everybody else except me, it's me.
MarkMark
Hi Matt-
Glad to hear all is working! As our good fried Ockham Says, "The simplest solution is always the best one."
I will update the sticky at the top of this forum to reflect this.
Pierre-
I am a bit confused by your last post. Are you still seeing the #1 security issue? This was fixed in that latest updater build. Also, I have not seen myself nor has anyone else seen the Missing config button issue. I can't really tell if these are resolved or not, so please let me know.
Thanks all!-RJ (HomeSeer Tech)
RJ-
Any insight into the timer event issue mentioned earlier in Posts #183 and #184?
I can't offer much explanation. It appears that these events are created by the plugin when a SG timer is set. Sometimes these events go away and sometimes they don't (and thus they accumulate in the Events list). I deleted 175 of them tonight.
MarkMark
KLS
Originally posted by mattdbOh my God. What a $#^$%^$%^$%^ing idiot. Other was disabled. That is why I kept seeing INFO in the log.
Good job Matt, glad to have you 'on-board'!
It's time for:
Hi Mark-
Haven't had time to look at that yet. I will tell you that these events are created by the plugin, and they should be deleted as well.
I don't know what the original intent of these events was, but I will be looking at this on Friday when I am back in the office. I did some minor cleanup on that code a while ago, but I haven't looked at it too recently to be sure.
RJ-RJ (HomeSeer Tech)
scanr
Equipment to Test with
RJ,
If you would like, I have an LCD, IO Xpander, IR Xpander, and 485 hub I will let you use for a couple of months to finalize plug-in testing. Let me know where to ship to.
I'll buy you a RCS 8R5PR 8 channel RS485 Relay Expansion if you would like one to write and support plug-in.
Pete
Originally posted by RJWow you guys post fast!
I am in all day tomorrow to look at everything. So far, the issues to address are:- Missing Config button
- Relays not being tripped
- Relays on external units
- Weird timer events
To users with timers: Is there any sequence of events in either Stargate or HomeSeer that could cause this to happen? If you can get something repoduceable, then I will do what I can to find out what is wrong here. Please remember the Stargate unit we have here at the lab is basic: no expanders, keypads, etc, and it can be tricky to ensure all components in a system this broad are functional.
To Matt and other new users: Hang in there! This plugin is still a work in progress (hence the BETA label!) We will get it working right, you can count on it!
Another topic: Thermostats. Right now, we do not plan to support the thermostats. This has not been my decision, and we are not going to work on this anytime soon. However, if 6 months down the road there is a bit of a lull in development, we may consider adding this in. But for now, PLEASE remember that this WILL NOT be added. (I really think I've said this a million times!)
On a lighter note, I will have another build tomorrow and hopefully a subsequent one either Friday or Saturday. If you have sent me a log, what I am really looking for is a "Scenario", i.e., I do this in Stargate, and HomeSeer does that wrong. Things like "This doesnt worK" don't really help much. If you have sent me something, I will look it over thoroughly tomorrow.
Hi Pete-
I appreciate the generous offer, but I don't think we'll be doing that right now. I would need to check with Rich Helmke anyway, and he is currently out in Denver with the rest of the gang.
The RS485 stuff is still not going to be implemented. This was not in the original plugin, so we don't want to add it right now. Bear in mind that if things are slow down the road we might support these, but for now they are out.-RJ (HomeSeer Tech)
Easier way to do RS485 stuff
If the serial protocol is so hard to work with making RS485 device support impractical, I'm just curious why the plugin is even using the serial connection? JDS themselves connect through the web expander for all new products such as HomeRunner and we know all the data and control stuff is available that way because you can access a web expander with any browser. Wouldn't this be a simpler portal for a Stargate plugin to use and one that already supports thermostats etc?
