Getting back on topic....
I can't get stargate to read any flag changes by homeseer either. I just reupped my firmware to 3087 (no to 4.0 due to IVR board).
I can send you what ever you need when ever you need it in whatever format you want. Shoot, I can even punch a whole in firewall if you want to play around or look.
Matt
PS: Thanks for the support, but sure seems like there is along way to go.
PSS: How on earth do you doa sequence in HS? Say if X10 A1 ON is pressed twice in a row, or if an ir command is pressed twice or say 1 then 0 on ir input?
I have come up with a solution that uses flags with stargate, but I really shouldn't have to do that with a 200+ software application.
PSSS: Is there a heavy duty syntax manual anywhere in pdf format or? Something besides the web. Want to print one out.
Matt
