Hello All,
Since the new Stargate plugin is now in the updater, this thread should serve as a "guide" to installing it, especially if you were using the older Stargate plugin under HS2.
Installing The Plugin
- Select "Updater" from any HomeSeer web page
- Follow the instructions until your reach the "package selection" screen
- Look for the JDS Stargate plugin for HomeSeer 2.1.x. Right now, it is labeled as BETA under Multi-Purpose plugins.
- Select the checkbox next to this package, then finish the updater.
- Restart HomeSeer.
- All configuration is now done via the web, as opposed to the old windows forms. Select "Setup" from any HomeSeer web page, then click "Interfaces"
- Look for the entry for the JDS Stargate plugin. If it is not enabled, click the "Disabled" button under Other, X10, or IR, depending on what you are using. Enter the COM port in the text box that will appear, then click "Save"
- A yellow "Config" button should appear. Click this and you will be directed to the configuration page.
- Change settings for the plugin on this page, then click "Save Settings" at the bottom when you are finished
- Warning: There have been significant changes to import functionality with this version of the plugin. It is highly recommended that you remove any existing Stargate Devices from your HomeSeer configuration before performing a fresh import.
- From the Configuration screen, click the "Browse" button. A dropdown list will appear below, allowing you to browse to the directory where your .DBF files are stored. When you have the directory selected, click "Import/Update Devices"
- A set up checkboxes will appear in place of the directory browser. Check the devices you would like to import, as well as whether you would like to overwrite existing devices. Warning: This may not correctly update devices imported using the old plugin.
- All devices should now be available with correct types and new controls.
- Shutdown HS2
- Copy the "irlbl.cfg" file from your HS1.x "Config" folder to your HS2 "Config" folder
- In your HS2 "Config" folder, delete "IR-Labels.ini"
- Restart HomeSeer
- Refer to the Plugin Help guide, located with the plugin.
- From any plug-in web page, click "Help Page" (one of the three links at the top) to view the help file.
