Error in HandleRelayEvent
This topic is closed.
    RJ,
    One other thing I could use your imput on. I keep getting the following error message in my HS log:
    JDS StarGate - Error in HandleRelayEvent: Object reference not set to an instance of an object.
    Can you give me an idea of what to look for to fix this problem? I have tried to no avail. It doesn't happen every polling interval, nor can I associate it with a particular event firing.
    Dennis
    Hi Dennis-
    If you can enable debug on the plugin (Function and Com), then send me a log segment where the problem occurs, I should be able to figure this out.
    -RJ (HomeSeer Tech)
      Miracle on 9th Street
      RJ,
      Maybe it's a Christmas miracle or perhaps my tinkering (no pun) solved the problem, but I haven't seen the error in quite a while. It may have been due to several duplicate events that appeared on an import, which I deleted. Now the problem is that HS "encounters a fatal error and needs to shut down" on a daily basis. I don't know if this is SG related or not. I'll keep you posted.
      Dennis
        HI Dennis-
        Glad to hear all is well. Just to follow up a bit: This is definitely Stargate related, so if it does appear again it is a problem with the plugin, not HomeSeer. If you can reproduce the problem with a specific series of events (Changing a relay, from HomeSeer or Stargate, etc.), that would be particularly helpful. If not, a debug log statement of the problem would be sufficient.
        -RJ (HomeSeer Tech)
          Originally posted by RJ View Post
          HI Dennis-
          I was something similar for a while, but it just went away.
          12/30/2006 6:25:19 PM ~!~JDS StarGate~!~Error in HandleTimerEvent: Method not found: 'System.String Scheduler.hsapplication.AddAction(Int32, Scheduler.Classes.action_type_value, System.Object, System.Object, System.Object, System.Object, System.Object)'.
          Matt
            Hi Matt-
            This is due to a difference in how HomeSeer 2.1 and 2.2 handle the AddAction function. If you need timers to work, you also need at least HomeSeer 2.1.122.
            http://board.homeseer.com/showthread.php?t=115864
            This thread discusses the change here slightly. It is a bit further down, but explains the reasoning.
            -RJ (HomeSeer Tech)
              Variable Duplication, etc.
              RJ,
              A new problem has developed. I'm at HS 2.1.162.0 & SG 2.1.2548.21307. The plug in duplicates some variables on import. I delete the variable, import and I get two of the newly created variables, exact copies. A check of SG shows only one instance of each variable with a normal value of 0. On import I not only get two of each previously deleted variable, but the value of each is 100. Also, the value cannot be set to 0 or decremented/incremented. And, the "Type" appears as "SG Varaible", yet the plug-in assigns an X10 code to the variables instead of an \n. I can reset,increment or decrement other SG variables in HS.
              Any ideas?
              Dennis
                Hi Dennis-
                What is the number of these Variables in HomeSeer and Stargate? Their HomeSeer code(A1, etc.) and Stargate index(1 to 255) will help me figure out what is going on.
                -RJ (HomeSeer Tech)
                  Duplicate Variables
                  I am seeing the exaxt same thing. I had to delete BOTH variables, stop Home Seer, restart Home Seer, and then reimport and everything was ok.
                    Number of Variables
                    RJ,
                    In reply, I have 99 variables listed in HS: \1-\11, \14-\81, \83-\96 (93variables), plus 6 others listed as Z2(Interface Variable), A3(Interface Variable), A4-A5(SG Variable) and A7-A8(SG Variable). These last six are the problem variables.
                    In SG I have 1-11, 14-81, 83-96, 98-101, 103-104. The 98-104 variables are the problem variables.
                    Also, I on my last try at deleting then re-importing the problem variables, I got a Log message for each problem variable (6) stating "DeviceClass error for [variable], invalid housecode. Reverting to the previous value."
                    Dennis
                      Log Clip
                      RJ,
                      A few posts back I mentioned that I was having a problem with a HS variable causing an event to fire even though the variable in SG did not change. I made sure that the event was configured to trigger on a "Changed to", but the event still triggers. The variable in SG did not change, but the event triggered. I was able to capture some debug info in the log, see attached. Note that there is no indication of the variable "JDS Home/Away Dennis Home" status changing. I ran the log from ##%20 to ##%20 preceeding the event firing to the same after the evnt firing.
                      I hope this sheads some light on this most vexing problem.
                      Dennis
                        Rj
                        RJ?
                        You out there? Did you get a chance to review my post?
                        Dennis
                          Sorry Dennis,
                          I think I lost this post while browsing the boards. I will take a look at this today.
                          -RJ (HomeSeer Tech)
                            Hi Dennis-
                            EDIT: Hold the phone, I am working on a fix for this now. Should be posted here shortly.
                            EDITv2: OK, I think I have a fix for this. Can you give the attached build a try?
                            EDITv3: Removed old build, see the updater.
                            -RJ (HomeSeer Tech)
                              Rj
                              Rj,
                              Sorry, I didn't mean to sound bitchy or pushy....my wife is a little over-anxious to get the SG LCD back working with HS so she can use it to play her playlists via media player.
                              I'll give the file a spin and let you know the results.
                              Thanks.
                              Dennis
