No Joy
RJ,
Replaced the SG dll with the one you sent, rebooted HS and deleted the 5 bad devices, exited HS, rebooted and then reimported the 5. All is exactly as before and described in previous post, including error messages.
I did make a bit of a discovery. All of the bad variables are at the end of my SG variable list. I moved one of them to an open slot closer to the top of the list. After deleting the variable in HS and reimporting, it appears normal in HS. Could it be that the plug-in only reads to a certain number in the table? As I stated before, the table does not go over 100, actually 1-96. I could not try to move the other 5 bad variables due lack of slots closer to the top.
Dennis
RJ,
Dennis
