GetEvent not reliable...Errors in AddDTMF
This topic is closed.
    I use DTMF a lot with my SG and have a few questions regarding what I am seeing in the HS log
    For example, when I use DTMF codes to set a flag in SG I see the following entries in the HS log:
    "GetEvent is not reliable for event enumeration. Please use the new GetEventEnumerator method. "
    "Error in AddDTMF:Argument 'Index' is not a valid value"
    What exactly is going on here?
    Greg
    Greg,
    It appears that using the TouchTone command triggers code in the plugin that still has residual statements from pre HS2 days. I suspect RJ will be able to answer your question. Have you submitted a help desk request to HST?
      That's an interesting theory. Since my installation is a brand new right out of the box vanilla installation, I would think that it would then be a common problem and there would be many who have seen this.
      I haven't submitted a request on this as I don't think it's a real problem, only an annoyance and I thought I could get an answer here instead of bothering RJ.
      -- greg
        Hey Guys-
        I'm fixing another Stargate bug right now. I should have an updated version posted here in an hour or so.
        -RJ (HomeSeer Tech)
          I have tried to use the DTMF functions (event triggers), but couldn't get them to work - I use HS Phone and expected the DTMF commands to correspond to HS Phone and not to Stargate. I didn't realize that the Stargate plugin offers any functionality with DTMF.
          Could Stargate be hijacking these commands for me, instead of routing them to HSPhone as I was intending?
          I was using DTMF as event triggers and having trouble. The DTMF events were showing up in the event log but not triggering events.
          Rather than wasting time on it, I just scrapped those events. But now that I see DTMF issues on the Stargate board, I realize that perhaps the Stargate is interfering with those DTMF commands and event triggers?
            Hi Tim-
            DTMF wasn't really touched when I revamped the plugin, but now that I am looking into it, it appears your speculation is correct. Can you give the attached build a try and see if it fixes anything?
            -RJ (HomeSeer Tech)
              I just used the build you posted for the SetTime fix, assuming it is newer than this build here. That build did not fix the DTMF issues. in fact, now I don't see DTMF from HSPhone showing up in the log - I'm pretty sure it did before????
              Were the changes for DTMF that you wanted me to try included in that later build?
              Tim
                Hi Tim-
                They should have been in that other build. Let me take a closer look so I can see what exactly is going on here. Can you enable Debug Com logging, and post a typical phone event here? There are quite a few trace statements in this code, so it might help me determine what is going on.
                -RJ (HomeSeer Tech)
                  Here's an update from my end.
                  See my original post at the start of this thread.
                  I installed my Way2Call and got HSPhone configured and now DTMF seems to work in both SG and HS. I'm still using the same version of the SG plug-in I started with.
                  Now what I get is after starting up HS I am seeing the following error in the log after Wave In id:2 (what ever that is): Error in InitVR100) Value does not fall within expected range. Don't have a clue what this is about?
                  I'm going to post in the HSPhone part of the board with this and other related stuff that is going on.
                  -- greg
